amp question and what's the difference between a fi BL and an AA havoc
Vooloco
I'm looking at getting 2 fi BL's or 2 AA havocs both 15". Fist of all should I run 2 amps or connect both subs to 1 amp(not a 2 channel, a mono). The amp would probably be an Audioque. AQ makes good amps still right? I don't really know if you even can connect 2 subs to 1 amp(kinda new at this). For the subs I've heard the havoc is more expensive then a loaded BL is that true? Can someone tell me how much a havoc is anyway? And what is really the differences between the havoc and the BL? Witch would be deeper/louder?
Thanks
You can wire more subs to one amp, you have to look what Ohmload your amp can do and what Ohm your subs. Like 2 D4 subs wired at 1 Ohm to the amp.
Like in this example to a 3.5 K amp.
Threw the subs the Havoc is known as a musicly more SQ sub. A full loaded BL sub would take more power than a Havoc.
"in the abundance of water, the fool is thirsty" Bob Marley
Yes AQ amps are fine..
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Hey, can you tell me what "lined power" for an amp means? example: 2 ohm Linked Power @ 14.4V @ 1% THD
Also do you think sundown amps are worth the price vs AQ?
  • Who's Online   0 Members, 0 Anonymous, 1263 Guests (See full list)
