stumped on my system setup
So I had a jl 12w7 and a rockford t1500bd hooked up in my car playing nicely together. Colorado winters are very cold,my dumbass turned the sub up too loud before it was fully warm and heard a pop/clip noise. system stoped working. Checked everything all power was good, all fuses were good,determined the amp was just dead. Ordered a new aq 1200d last week, it came in hooked it up right as the old amp was. No output what so ever. Metered the sub with a multimeter, impedence seems good. no noise when depressing cone, suspension feels tight, leads appear gravy, spider intact. checked all the connections, eliminated the headunit just used a headphone to 2 rcas pluged directly into the amp. gains are not all the way down,amp is on output master. Problem is I don't have any friends with systems to troubleshoot with so I'm rather stumped. Only time I got any response out of the sub was a small "pop" when I changed the amp from master output to slave. any ideas anyone?
Thanks in advance.
jl 12w7 ported @ 2cubes at 38hz
rockford fosgate t1500bd
is your remote wire in? its all i saw that you didnt put up.
and is the amp going into protect?
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
The amp is coming on fine, There is no headunit being involved in the setup, but got nothing with the Y cable straight into the amp. I did not change any of the settings of the amp out of the box, I dont think any of the filters would completely remove all movement in the sub.I tried hooking up the bass knob and no luck either. I think the only thing to do is find someone with a another sub/amp and interchange to troubleshoot.
maybe you should change your speaker wire from your sub to amp if you havent already :shrug:
didn't think of that, good idea. I'll try that tonight and see if it fixes it.
EDIT: NM saw you have a DMM ;) Check the RCA's to see if they are sending a signal.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
wasn't sure which setting to check these on, but I tried a couple and it was putting out a small reading on one of them.
  • Who's Online   0 Members, 0 Anonymous, 1592 Guests (See full list)
