Rebel4055 Posted September 22, 2011 Report Posted September 22, 2011 Sorry but your brother has some screws loose, NEVER add a ground to your amp. Only use the supplied terminals. Use the correct gauge wiring for that amp and ground the amp to the chassis(if it's a unibody car) if it has a frame like a SUV or truck ground it there. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
pimpnFosgates Posted September 22, 2011 Author Report Posted September 22, 2011 ther discontinued subs, they pound Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
Guest Posted September 22, 2011 Report Posted September 22, 2011 sadly its the best amp ive had): i just recently started making enough to do my expensive hobby.what would you suggest amp wise? i see you have those RF woofers, but what is the RMS on them and what is the resistance of the voice coils? 400 rms to 800 peak. for future reference, when any audio product lists Peak power, it means absolutely nothing. only look at the rms figures. so you have 800rms in woofers, what about the voice coils? if you cant find that out, give us a model number for reference.
97SSBlazer Posted September 22, 2011 Report Posted September 22, 2011 are your subs in the box? cause you said you spayed water on them. yes, poorly made box, ports lead right to top of sub.i dropped my phone in port so i found ouit it was hot trying to reach my hand in to get it. HUH? Can you supply pics so we can see whats going on? lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz. -= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash Subs: 2 T1 12's Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:) 2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/ 2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/
pimpnFosgates Posted September 22, 2011 Author Report Posted September 22, 2011 Sorry but your brother has some screws loose, NEVER add a ground to your amp. Only use the supplied terminals. Use the correct gauge wiring for that amp and ground the amp to the chassis(if it's a unibody car) if it has a frame like a SUV or truck ground it there. its a blazer, ill remove that ground, and then ill remove the ground off my 4 channel in my current build. Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
pimpnFosgates Posted September 22, 2011 Author Report Posted September 22, 2011 rfp4212's and does anyone have recommendations on an amp. Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
Rebel4055 Posted September 22, 2011 Report Posted September 22, 2011 Sorry but your brother has some screws loose, NEVER add a ground to your amp. Only use the supplied terminals. Use the correct gauge wiring for that amp and ground the amp to the chassis(if it's a unibody car) if it has a frame like a SUV or truck ground it there. its a blazer, ill remove that ground, and then ill remove the ground off my 4 channel in my current build. There you go, GROUND THE AMP TO THE FRAME USING THE TERMINAL SUPPLIED Also make sure to grind the paint away. Sorry had to make sure I got the point across. Oh also, do not run RCA's with power wire. Could cause "noise". And the gain on the amp is not a volume knob. And NEVER use bass boost. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
pimpnFosgates Posted September 22, 2011 Author Report Posted September 22, 2011 are your subs in the box? cause you said you spayed water on them. yes, poorly made box, ports lead right to top of sub.i dropped my phone in port so i found ouit it was hot trying to reach my hand in to get it. HUH? Can you supply pics so we can see whats going on? i live in florida and its pitchblack out. so not really. Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
Guest Posted September 22, 2011 Report Posted September 22, 2011 rfp4212's and does anyone have recommendations on an amp. thanks for the model number, found out that they have dual 4 ohm voice coils. this amp would work well for them http://www.audioque.com/AQ750-Amplifier_p_46.html it has a clip light on the bass knob so you'll know if you're giving them clean power or not.
pimpnFosgates Posted September 22, 2011 Author Report Posted September 22, 2011 Sorry but your brother has some screws loose, NEVER add a ground to your amp. Only use the supplied terminals. Use the correct gauge wiring for that amp and ground the amp to the chassis(if it's a unibody car) if it has a frame like a SUV or truck ground it there. its a blazer, ill remove that ground, and then ill remove the ground off my 4 channel in my current build. There you go, GROUND THE AMP TO THE FRAME USING THE TERMINAL SUPPLIED Also make sure to grind the paint away. Sorry had to make sure I got the point across. Oh also, do not run RCA's with power wire. Could cause "noise". And the gain on the amp is not a volume knob. And NEVER use bass boost. i know about the gain knob and all that. i set my deck to where i would max it out then tuned the gain to where it sounded good. doesnt bottom out n no distortion. and i know about the rca and power wire thing. thank you. Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
