DC Sound Lab
I have an XL which the neck joint failed on it.. I was throwing about 3kish daily to it and the thing was loving ever bit of it... It flexed my car super hard and would hit down about 26hz really well. Box is tuned @ 33hz and is 3.4 cubes my 3sixty.2 is set @ 28hz filter and -5db on 25-40hz on the sub side. I'm going to be burping it with around 5k going to it... But daily wont put more than 3.5k to it. Very clean voltage doesn't drop below 12.8 full tilt.
I was thinking 5 mediums 1or2 stiff spiders but I still want the lows to hit well... Just wondering if anyone has this and how it hits.
Also have heard of some surround strengthening options would you recommend that?
The sub is still playing i have now ripped one side of the leads in half because the neck joint failed. Its playing on 1 coil with 1.8k going to it and still is one of the loudest best sounding subs in my area :) DC FTW!!!
1 Crossfire XS v2 15"
2 Deka group31a's
1 XS Power D3400 (under hood)
1 Addictive Audio 500.1 :D
1 Rockford 3sixty.2
4 Crescendo pwx 6.5s
2 Pyle Pro Super tweets
1 Crescendo 1000c4
Kenwood excelon x494 Head unit
Big Three upgrade
All 0 gauge of course
1 4.56c^ft box @28hz
(New Best official db score= 151.2 @ 36hz)
in for info as i will have around same amount of power on mine. :good:
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
Corona jeff runs 2 ab 1100s on his 4xls with that spider configuration.I had it also but had a messed up eq that sent a 4k plus clip to my subs. I didn't lose my triple joint but I ripped my spiders.. now I have 4 stiffs 1 med and they sound great.it depends on what your trying to accomplish I've talked to rusty a lot about this. The stiff break in and will loosen up the med all though thinner keep there stiffness longer
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Ok so because I daily my subs much more than compete should i go for the med spiders with the single still or more stiffs lmao
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
Med never fully loosen up stiff do but still have resistence. Call rusty
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I've been talking to Rusty :) He has been a huge help i just came to the idea of asking you guys who have used the setup and also know what your doing! It helps cause he said the extra spiders will change the fs. I just wanna be able to slam the low notes still and be able to burp it on the occasion! Thanks for all the input guys SMD rocks :drinks:
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
The only thing about adding more spiders is that it will take longer to break in.
That i have no problem with.. When i had my 2011 T2's they took 3 months of daily pounding with 3k to each to break in fully lol... I just love this sub in every way more than any other brand I've had... Best sounding and loudest for the $$$ by sooo far lol
Now if I could just get a neo :shrug:
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
  • Who's Online   0 Members, 0 Anonymous, 3489 Guests (See full list)
