Dual input adapters? any gain?
im pretty sure that you should gain. allowing more current to flow can either help give more actual power to your amps so on paper you should she increases. plus they're sexy as hell.
a guy i know used the b3500 and couldnt get all the power because his 1/0 was starving the amp. switched to dual inputs and could play his system louder for longer.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
It will help, to a certain extent. For example, let's say that your amp pulls 375amps on a full burp; but your 1/0 only carries 300a for your length. Dual inputs will help because your voltage at the amp will drop.
However, if you have 2/0 that carries 400a, then dual inputs probably won't benefit you (considering there isn't much resistance).
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Where do they sell them?
go to caraudioclassifieds.org and scroll down to the "toolmaker" section. i believe you have to call him
  • Who's Online   1 Member, 0 Anonymous, 1948 Guests (See full list)
