Chambered vs open....
brent379
Is there a difference in sound or pros and cons in.boxes that are chambered vs non chambered?? Does that question even mas ke sense??? I suck at wording sometimes....
ported you mean? Or are you thinking of bandpass boxes?
Hammerdown... 1%
you mean multiple subs in a single chamber or each sub loaded in its own individual chamber?
this I'm pretty sure
yes there is a difference but it's minimal. From what I've seen and read "open chamber" as you put it are good for SPL style setups and or ppl trying to save space but doesn't save much. You can can get a little more SQ out of independent chambers.
But all in all there's not much of a difference.
Yes, if one sub blows and you have separate chambers, your other sub will still play in the right amount of air (enclosure). If you had two subs in a "common Chamber" and one blew you would effectively double the air space for the one good sub to play in, which would result in less than optimal performance. The drawback to separate chambers is that it is easy, due to human error, to not get the chambers exactly right as far as square inches go and port surface area, so the chambers if not exactly identical would be slightly off as far as tuning and back pressure. If your set up is for everyday use and you're not pushing your subs to the limit, "common chamber" (shared air space) would be the way to go. If you think you could blow one and still want to bump until you get a replacement, then separate chamber is what you want, just take your time with measurements and your cuts when building the box.
2001 VW Passat Sportwagen
Alpine ICS-X7HD
DC Audio 5K
SSA 15" XCON
Tantric Sounds 6.5HD's, Sundound Audio SA-6.5CS
Incriminator Audio IA6.4
XS batteries, KnuKonceptz wirez, Second Skin
i've never built a multi-chambered box. Waste of time.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 893 Guests (See full list)
