can you ca glue the lead wires to the top rib on the spider with added slack between the ribs?
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
I highly doubt that will work since the entire spider will be moving in and out with the speakers play. Some people and manufacturers have added foam adhesive pads to the woofers cone to stop tinsel slap. Now good luck finding something thats sticky enough to remain on your subs cone, you may have to add a crap ton of extra glue for it.
so i gotta find a foam pad thatll work and ca glue that to the cone
^^ what he said. You can try to do something i found on a few of my indoor subwoofer enclosures. They have foam that is hollow and has a sticky backing. They wrapped them together around the leads of my subwoofer and it didnt have any slap from the tinsels.
I know my XL had felt pads. Felt will work fine for a while. Bit once your tinsels start slapping it's only a matter of time before you need to start considering a recone and figuring out what you were doing wrong... What kind of subwoofer?
P.S. I restitched mine the best I could to the spiders then put a coat of super glue over them and the stitch point and let the glue cure. Worked great for the longest time-
1997 Chevrolet Cavalier Two 12" DC Audio XL M2'sCrescendo Audio BC5500d
Current Scores: 150+ out the Trunk
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
i might need to do that all 4 of my leads have broke cause when i did my recone i didnt give them enough slack. and the leads i ordered to fix them where mad small im now odering .80 leads so i gotta eather do that ^ or extend the foam pad thats on there with new ones one each side
get sewn in tinsel leads :-)
kinda 2 late now they have already be reconed where would i sew them on though the high ribs/ putting a needle threw the spider wont effect it?
  • Who's Online   0 Members, 0 Anonymous, 1350 Guests (See full list)
