new guy Posted September 25, 2011 Author Report Posted September 25, 2011 i just checked and my max depth is about 31 too. Quote *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit
new guy Posted September 25, 2011 Author Report Posted September 25, 2011 this is with the dimensions you gave me. Quote *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit
CJ18 Posted September 25, 2011 Report Posted September 25, 2011 Do you have access to a router with a flush trim bit? Quote
CJ18 Posted September 25, 2011 Report Posted September 25, 2011 (edited) this is with the dimensions you gave me. Port height needs to be 16.5 and width 4, Also put the .18 for woofer displacement Edited September 25, 2011 by CJ18 Quote
new guy Posted September 25, 2011 Author Report Posted September 25, 2011 no the only tools i really have is a jig saw and a drill some wood clamps and little stuff. i usually have lowes cut the wood for me. but if i need one i could see if one of my friends have one Quote *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit
CJ18 Posted September 25, 2011 Report Posted September 25, 2011 Can yo make the adjustments to torres I have listed above and post them. I have a cut sheet done but just want to make sure it all works out before I send it to you Quote
new guy Posted September 25, 2011 Author Report Posted September 25, 2011 here ya go Quote *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit
CJ18 Posted September 25, 2011 Report Posted September 25, 2011 1) Start with just the bottom 2) Glue and nail/screw the back on 3) Glue and nail/screw both sides on 4) Glue and nail/screw front on 5) Glue and nail/screw port b to port a 6) Glue and nail/screw port into place, making sure that you have a continuous 4" port 7) Seal all corners with silicone to prevent any possible air leaks. Glue and nail/screw top on. Make sure to mark the center of the port onto the top so that you can nail/screw through the top into the port. 9) Mark and cut out hole for sub 10) Install box and sub into car and go boom. Quote
new guy Posted September 25, 2011 Author Report Posted September 25, 2011 ok that makes sense. thank you so much, you have no idea how much you have helped me out. Quote *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit
