what does a subwoofer box tuned at ? mean ?
KHRISS
im only suppose to use 1 of the 2 speaker terminal RIGHT?
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
not necessarily both sets of speaker terminals are parallel its just an easier way to wire multiple speakers to one channel EX: if you have 2 subs that are 2 ohm each you use both sets of terminals (one for each speaker) but if your speakers are dual 2ohm are you do this the amp will go into protect because the ohm load will be too low
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
lets say spl meter would they judge you on your set up or just the numbers you put up on there meter
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
just the numbers on the meter
but your setup matters when you get put into a class
xbl7c4.gif can i do this wiring and use 1 pair of the 2 speaker terminal and still get the 3540 watts of the amp?
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
since you have the CP model yes you should because if remember they do the same power at 1ohm and 2ohm
judging by my SIG what class would i be
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
but even then it's not as easy as simply wiring speakers and getting all the 'watts' out of an amp.
OP...do you have all this stuff lying around or is it installed?
your class depends on your setup/box style, fuse rating, etc depending which comps you go to
^ this it also depends on how it is in the vehicle is it a wall is it behind the c pillar or b pillar is it below the window line the number of batteries all kinds of variables could contribute to your class... main reason im rebuilding right now
  • Who's Online   0 Members, 0 Anonymous, 1303 Guests (See full list)
