are you sure it is coil you are smelling or just glue?
it could be the glue i remeber one of the recones the person who made them did spill one glue on one of the sides of the coil
What I meant is
Was your gain set lower than you have it now? As in BEFORE you tuned with DD-1.
o lol i honestly dont remeber i didnt even look i justed tuned everything down to 0 on all the setting when i was tuning my stuff
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
okay guys you think i should use the -5db? track the one i used track 7 was the -15db track
there -5db -10db and -15db to choose from
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Posted (edited)
Think about this; if you set the gain with the -15db track, then play a song recorded at -5db(which is way louder), you'll have serious clipping issues.
ahh okay so its just the song that is sending the clipped signal i will change as we speak
okay i just adjust it and when i put that track on it showed it was clippin i turned it down the dd1 says im good but the gain knob is full on full clip mode its just holds i steady red light
Edited by KnockinthaStreetzof608
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
also my subwoofer is at 0 my crossover is on 80 and my phase is normal
should i change my 0 to -5? and my crossover lower to like 60 maybe?
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Posted (edited)
Crossover is fine at 8 0. You can turn the sub setting all the way up, then you will need less gain on the amp.
what u mean by all the way up like the highest + (highest number my hu has) db
even when i do this and the dd1 says im fine the aq gain knob is still on full clip
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
I don't know what else to try. I DO know that the clip lights can be a bit off. Mine comes on, too, but I just ignore it. My subs do not get warm at all though.
never mind i got it all worked out stupid aq and the reverse gains thanks ken i fucked up on the ss filter when i was setting it
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
  • Who's Online   0 Members, 1 Anonymous, 730 Guests (See full list)
