Man that sucks you gotta build a new box...newbie alert...did you just router the mdf for the rounded edge? Are there any links to doing that? ok newbie questions overwith...
thanks! :) i had to sand the port down with a belt sander. dont have a table router to use. and didnt wanna mess with a hand router. probably the trickiest part so far.
:lol:
DC.jpgDC POWER
i dont HAVE to build a new box. just choosing to :) lil experimentation for better sound. but yeah...i coulda used a guide and all that (given that my cuts were EXACTLY straight as to not curve in or out of the port). but the side that the router is on in my garage is cluttered to hell. and i didnt feel like fishing around and getting the router out and all that, even tho i will have to in order to cut the holes. and on top of that i'm not sure if i had the right bit for it. so i just used a belt sander instead since it was right next to me. then smoothed it out. wasnt too hard, just makin sure it was equal all around was kinda tricky. but it's all good.
Why if I might ask couldn't you do it with a hand router? Couldn't you just put a jig on the box and use that as a guide?
hmmm...i think you're talkin about a different tool than i'm thinkin. clamping a straight edge to the box? that might've worked too, but i felt more comfortable with the sander. gave me more control and the price for error is less. cant gouge the wood with a sander like you can with a router
Were talking the same thing! Straight edge as well! I was just curious what all you guys use for the rounded edges...the router is what I'd use but not for sure what you guys have been using...
Yours looks fine without using a router!
from the looks of it your going to get better airflow! Good work on the sanding!
thanks and thanks!
yeah i'm looking forward to more air flow. more air = hair tricks :) i'll be happy if i can do those...
