The FI Q series, but be careful how you wire them up, they should be able to take a 500 watts more. trink40.gif
UNDER-CONSTRUCTION
''Old School Build''
maybe it sounds like an 18 cause theres 3 fucking "port" holes ghetto drilled in the "box"
190 db when your done?
Yea that's the lowest decibal ill be satisfied with when I'm done like I said its stage one and I lost my job u guys should consider shit instead of just talk it
lmao
Could it take 2k?
Edited by AdamTheAudioMan
UNDER-CONSTRUCTION
lmao
What is your amp that you are going to be running to the sub?
You may be saying 2K, And its rated for 2K, But doesn't mean you will get the 2K out of it.
I personally, Would choose the SSD with Cooling option, And Dual 2 if your going to just run a single sub setup. And in the future, You can get a 2nd one, and a 2nd amp, Strap the amps, and have a 2 ohm final load, and ends up 1 ohm per amp.
Btw, You could feed it more power, You just have to be sure you are NOT CLIPPING the sub. You should be perfect.
But that's just me though. :pardon:
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
was sup with the multi threads
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
Why the SSd over the q? What's the difference iyo?
you know your not gonna buy any 15 any time soon lol
Edited by KHRISS
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
Maybe...read the RMS values that are in the t/s parameters on the speakers themselves?
They might be there for a reason.
With 2kw, I would suggest a BL with full cooling.
Authorized Ascendant Audio Dealer! Message me for information.
If you can't explain it simply, you don't understand it well enough -Albert Einstein
"I have a plausible excuse for not liking you. And you know why."
  • Who's Online   0 Members, 0 Anonymous, 2942 Guests (See full list)
