Idk if this is the right section to post this.
Anyways,one of my limos started acting funny,ac would sometimes turn off and turn on when it wants to.music would reset also.it was annoying,so I checked everything that might be causing it.
I ended up with the alt set up,I got a dmm and check if it was charging,it was.than I unplugged the 2nd alt and the stock alt Wasn't charging at all,so I thought it blew,took it out and tried getting it tested at autozone,but they didn't have the harness to plug the alt in,same thing with kragen,so I took my chances and bought another alt off my friend.I put it in and samething.
So I want to know if there's a fuse or a way I can check if the the plug is working to charge the alt?
Beacuse I know it ain't the alts now
I replaced the aftermarket(2nd alt)w/ one of my dc power 270s and it powered the whole limo like a champ,i can leave the alt in there but I rather fix the problem and do that as my 2nd choice,thanks
This is a 2007 cadillac escalade ext
Edited by deepsilencer
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
check for a fusible link. Are you getting any power at the lead? disconnect it while the truck is off and see if you have 12 volts. if im thinking right you should have 12 volts from the battery because its connected to the battery still. if not. theres your problem.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I tested both plugs,2nd harness is reading 12.6
And stock one is not reading,Damn
I checked all the fuses under the hood and inside the truck,nothing is blown
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
Do these plugs go bad?
Might be a bad plug,sucks because the truck is brand new
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
you can try a new plug. ITs 20 bucks from rock auto. id follow the lead form the alt first and see where it goes. Ive seen a fusible link pop and all fuses check out etc and after hours of cursing at it you find the link is bad.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thanks nate,ill do that right now
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
Fusible links are only on the output lead.
If you check voltage at the charge post you only get 12v when running?
The alt is tuned on via the bcm in that truck.
