Swapped cd players and rcas going to epic160 thing was slamming for a couple of hours hard then cutting out again. Did some testing today and was slamming hard off and on all day what could the issue be?
05 Suburban
Pioneer 4200ub
4-American Bass 6.5 , 2-8" DB Drive mids and 4- Quantum Audio Supertweeters in front doors
2-DD3515 dual 2 ohm subs
Rockford Fosgate 400.4 on 8" mids
Hifonics 80.4 on 6.5 and tweets
2-Hifonics BRZ2400's strapped @2 ohms
Project Caddy in the works
95 Cadillac Deville
I havent tried that but I would assume that its fine being that the voltage only drops to low 13's when it is bumpin
05 Suburban
Pioneer 4200ub
95 Cadillac Deville
im willing to bet its avoltage issue. your electrical is not on par for that amp
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
But the thing is for days it will work fine then it will stsrt cutting out. If it was a voltage problem wouldn't that be a constatly cut out?
05 Suburban
Pioneer 4200ub
95 Cadillac Deville
i have had this issue with a couple of hifonics amps and what i have found is they do not like low voltage to the rca's .....after a while some headunits and sond processors get warm and lose out put voltage (mostly head-units my audio control does as well )if you have it ran thro the audio control un-hook it and use the line drive i got a soundstream bx-15 bass machine and have not had the issue since....anther thing with them is they will fade in and out like ur dropping a voice coil if you have them turned down 2 low.... im not sure if this is the same with the colosus but i know the bxi,brz and hifi all have had those issues test the rca voltage while it is doing it best way would be to get a spliter/Y rca and hook in @ the amp test the out put with a digy volt meter.
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
