Shit man! I meant overrated like kranny said! My bad I was in class trying to keep my phone hidden haha
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
also, you need to figure out how youre gonna get any power out of the amp(whichever amp you choose) with TWO subs connected. you have a dual 2 ohm sub now yes? adding another will bring you to a final ohm load .5 ohms, 2 ohms, or 8 ohms. so whichever amp you choose needs to put out STOUT power at 2 ohms, or you need to swap the current sub out for a Dual 4 ohm coil setup(or dual 1's). Dual 4 VC's will wire to a final load of 1 ohm and that's the likely configuration you'll want with a 1 ohm stable amp. hope my post wasn't too confusing.
i totally understand what you are saying.... thats why i want 2 seperate amps that are 1 ohm stable ..... so i could wire each sub to 1 ohm and put them to their own amp.
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
i checked out the brutus series and i like the 1200w one. i think its brz1200.1 ....but my question is : how do you guys run @ .5 or less ohms safely? can this amp do it? i know it probably cant but i was just wondering... and also if i did wire them down to .5 wouldnt box rise bring it back up past 1 ohm? and is that a possibility? cuz i know i prolly have significant box rise as im using a prefab box that is about 2 cf too small lol these subs take 2 cf per sub in a ported box.
/ LOL
big 3
you wire to .5 by getting the right coil configuration with your woofers. if you have to ask if you can wire to .5 and have it work well, dont do it. simple as that.
its usually not recommended to do .5daily.
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
ok thanks guys!
/ LOL
big 3
