CarbonCone Posted October 17, 2011 Report Share Posted October 17, 2011 I only do burps don't do any bass racing so would a high output alt help me in anyway? or would getting a xs power charger and running 16volt battery in the back be a better idea or anything else out there that would help get more DB. Running Standard Alt D3100 2x 12" atmoic apx 2x 3000d E-Audio amps Dual Box 6" Port. Doing 151db. Quote Link to comment Share on other sites More sharing options...
BassMunky Posted October 17, 2011 Report Share Posted October 17, 2011 yes get extra battery man your volts must be dropping like crazy. What car is this from anyway? Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
CarbonCone Posted October 17, 2011 Author Report Share Posted October 17, 2011 Drops down to 12.6volts with 6000rms burps for 3 seconds Its in a mk4 vw golf. So do away with a high ouput alt and get more batteries Quote Link to comment Share on other sites More sharing options...
BassMunky Posted October 18, 2011 Report Share Posted October 18, 2011 try get another opnion. Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
vettedude102 Posted October 18, 2011 Report Share Posted October 18, 2011 (edited) I think get the alt. The batteries help it play for longer periods of time. You already have the 3100 so it's probably a strain on that alt if you put more batteries. Just my .02. Edited October 18, 2011 by vettedude102 Quote 2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette 2003 corvette z06 alpine radio and the bose system that came stock Link to comment Share on other sites More sharing options...
Mario928 Posted October 18, 2011 Report Share Posted October 18, 2011 I think get the alt. The batteries help it play for longer periods of time. You already have the 3100 so it's probably a strain on that alt if you put more batteries. Just my .02. I dont mean to be rude but i think your wrong unless the website is wrong. i found this on http://www.kinetikpower.com/2009/faq.asp I qoute "I heard that adding more batteries to my car will lower the voltage and is harder on my alternator, is this true? Adding multiple Kinetik Power Cells to a vehicle will not add extra load on your alternator or lower you voltage in your car like adding ‘wet cell’ batteries will. Due to the low ESR and high voltage of Kinetik Power Cells, your voltage will actually increase. Kinetik Power Cells also charge more efficiently and quickly than a standard ‘wet cell’ battery reducing the stress on your alternator." Quote Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
vettedude102 Posted October 18, 2011 Report Share Posted October 18, 2011 I think get the alt. The batteries help it play for longer periods of time. You already have the 3100 so it's probably a strain on that alt if you put more batteries. Just my .02. I dont mean to be rude but i think your wrong unless the website is wrong. i found this on http://www.kinetikpo...om/2009/faq.asp I qoute "I heard that adding more batteries to my car will lower the voltage and is harder on my alternator, is this true? Adding multiple Kinetik Power Cells to a vehicle will not add extra load on your alternator or lower you voltage in your car like adding 'wet cell' batteries will. Due to the low ESR and high voltage of Kinetik Power Cells, your voltage will actually increase. Kinetik Power Cells also charge more efficiently and quickly than a standard 'wet cell' battery reducing the stress on your alternator." Thanks for that. I learned something new today lol. Gotta admit I'm a when it comes to electrical. Quote 2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette 2003 corvette z06 alpine radio and the bose system that came stock Link to comment Share on other sites More sharing options...
TeamHT Posted October 18, 2011 Report Share Posted October 18, 2011 (edited) LOLZ @ Kinetik Edited October 18, 2011 by TeamHT Quote Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
Mario928 Posted October 18, 2011 Report Share Posted October 18, 2011 I think get the alt. The batteries help it play for longer periods of time. You already have the 3100 so it's probably a strain on that alt if you put more batteries. Just my .02. I dont mean to be rude but i think your wrong unless the website is wrong. i found this on http://www.kinetikpo...om/2009/faq.asp I qoute "I heard that adding more batteries to my car will lower the voltage and is harder on my alternator, is this true? Adding multiple Kinetik Power Cells to a vehicle will not add extra load on your alternator or lower you voltage in your car like adding 'wet cell' batteries will. Due to the low ESR and high voltage of Kinetik Power Cells, your voltage will actually increase. Kinetik Power Cells also charge more efficiently and quickly than a standard 'wet cell' battery reducing the stress on your alternator." Thanks for that. I learned something new today lol. Gotta admit I'm a when it comes to electrical. Glad i could help you. Quote Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
Mario928 Posted October 18, 2011 Report Share Posted October 18, 2011 LOLZ @ Kinetik whats funny about kinetik? Is the info wrong? Quote Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
