Building a box for 2 10s HELP!!
Krazykid122
ok so i was messing with the RE box calculator, and im not sure how to get it just right, i dont want my port to be to small to have port noise, but when i try and make it bigger and mess with everything else i cant get the tuning as low without messing up the volume.
i have 2 10s, trying to put them in 1.5 cubes (.75 each req.) and tune between 33 and 37hz preferably about 35Hz.
can anyone help out? im stuck.
02 Dodge Durango
1 Fi SP4 18" .v2
Sundown SCV3k @.5 Ohms
XS D3100 up front
Northstar SMS AGM 400 in the back
All XS Power 0ga OFC
240a Apex h/o alternator
Pioneer AVH-X2500BT HU
Dual 0ga runs from the alt to battery
Dual 0ga runs from battery to amp
download Torres box calculator from the subwoofer/enclosure section. Its better than RE's
Big 3 with Yellow Top
i just looked @ re box calculator and it is a lil off most of the time but i came up with a box that may workhere is what u need to type in
box width...28"
hight.18"
top depth.18"
bottom depth 18"
sqaure port with 3"
sqaure port lenth 12"
this should give you 3.292 cubes and tune u @32hz-34hz (Re seem to be of a lil bit)
anyway thtas the best i could come up with fast i will look into it later to be sure ...im sure some1 with more knowledge will correct me if i am wrong as well...good luck and be sure to build it with glue and screws....if you can i would 45 all corners as well.
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
  • Who's Online   2 Members, 0 Anonymous, 1872 Guests (See full list)
