Amp problem
seb43
Hi guys , something wrong with my amp atm . I just set my gain at 34,64 v on my aq1200d . 1ohm X 1200 root = 34,64 volt . My voltage is at 14v on the volt meter . Bass boost on the amp is 0 , lpf and subsonic set . All the setting on my hu is at 0 , except hpf at 100 . The volume is at 46 on 62 . My remote bass remote is on max . I'm sure i'm not getting all the power i can't . I doesn't sound like 1100-1200 rms at all (with my 2 sa'12 ) . The box is nicely done at 30 hz . The only thing I can think is how i wired my sub . I only connect 2 wire in the 4 terminal on my amp . Like 1+ and 1- . I followed this tutorial :
. Sorry for my bad english . Hope you'll understand what I mean and find my problem thank
Turn your gain up more, that method sucks lol
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
The way you set the gains isn't the best way at all IMO. And some amps that are 1 channel have two + and - for ease of wiring ( so if there is a few subs on it you don't have to cram 6 wires in one hole. Both + and - are internally connected( when I say this I mean both + are connected but separate from the two - that are also connected to each other), you can use 1 or both and you will get the same ohm load and power. Are you sure the subs are wired to 1 ohm?
Yea i'm pretty sure . But when i test with the dmm it tell me .3 . It should be arroud 1 . And what the other solution to set the gain ? btw i have an pioneer deh-4200ub hu
Dont test the ohm load with the amp on, that is probably why you are getting .3. I don't want to sound like a broken record but and oscope or the dd1 is the only real way to do it.
  • Who's Online   0 Members, 0 Anonymous, 635 Guests (See full list)
