ok so i what to make some brake dust shields for my wheels on my car that will fill on the whole rim like this
and i was going to use some red carbon/kevlar mat to match the red carbon/kevlar dust cap of my dc subs and was wondering what type of resin i use how many layers best way to lay it and how to polish to a gloss finish !! any and all help would be wonderful !!! behind my wheels its not that good looking and im sure that this would make it look really nice with my white rims over them !!!
Epoxy resin is what you use on carbon/kevlar. Using a gelcoat would be your best bet since you're using a color carbon/kevlar.
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
Im not sure of how much heat the gelcoat will take but try it on something metal and stick it in the oven.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Would I use both like epoxy resin as the base and then gelcoat for the top layers to show color ?? And how many layers would be best I plan on making mdf template and then flush cut the carbon on router table I was thinking 1 or 2 mm thick
Correct. Make sure you tint your base coat black. Use at least 3 coats.
Edited by Bigballa39213
Stock Everything
The New Setup
4 - RE Audio SX12D4
Ok thanks do they make special dye for resin ?
Wherever youre getting your resin from should have it.
Stock Everything
The New Setup
4 - RE Audio SX12D4
