How do I do this?
I really want to hook up a HU in my garage with a car battery and a sub and car speakers and all that but how would I hook up my HU without a car wiring harness or anything like that?
-EGAG
1994 Jeep Cherokee
!@#$%^&*(Soon to come)*&^%$#@!
TONS AND TONS of Audio Technix 80Mil
1 x 270 Amp Mechman Alt
1 x AQ3500D.1
1 x Rockford Fosgate T600-4
8 x Rockford Fosgate T2652-S
2 x XS Power D3100
1 x XS Power D3400
1 x eKs Kable 2 Channel Silver Plated RCA 5M
1 x Knukonceptz Kolossus Fleks Kable 1/0 Red 50FT.
1 x Knukonceptz Kolossus Fleks Kable 1/0 Black 50FT.
4 x Avenue - A605
2 x Fi Q 18
Help anyone?
1994 Jeep Cherokee
1 x AQ3500D.1
2 x XS Power D3100
1 x XS Power D3400
4 x Avenue - A605
2 x Fi Q 18
Power from the HU to a cheap on/off switch, then run the switch to the battery positive. Negative to the negative battery terminal...
Pretty simple really. Just gotta keep the battery charged and not run more than a few hundred watts.
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
Thats not really helpful could you possibly explain a little more? Like the switch part?
1994 Jeep Cherokee
1 x AQ3500D.1
2 x XS Power D3100
1 x XS Power D3400
4 x Avenue - A605
2 x Fi Q 18
take the red and yellow wires and twist them together then attach it to one side of the switch.
attach a wire to the positive end of the battery to the switch. then put the ground on the negative terminal.
also you might wanna rethink doing a sub unless you put maybe two batteries together and have a trickle charger hooked up to em
Edited by bass_stalker
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Wire red constant wire to battery +
Wire ignition switch yellow wire to a on/off switch then to battery +
Wire ground black/Brown wire to battery -
Do the same for the amp as well
stevemeadedesigns.com/board/topic/105505-silvia-first-time-build-kenwood/
The yellow is constant and the red is accessory
2016 Ford Explorer
2014 Ford F-350 crew cab
2012 Cadillac CTS-V coupe
2008 Lexus GS430
I got it all hooked up :) thanks guys :)
1994 Jeep Cherokee
1 x AQ3500D.1
2 x XS Power D3100
1 x XS Power D3400
4 x Avenue - A605
2 x Fi Q 18
  • Who's Online   0 Members, 0 Anonymous, 757 Guests (See full list)
