DC Sound Lab
I sold my DC LVL3 12s to a friend he has had them hooked up in a box I built for a couple years now (I know they are out of warranty). Anyways he called me the other day saying the subs were sounding really weird and barely hitting. Evidently the sub below disassembled itself and pulled the positive and negative out of the push downs which caused the other sub to play in the box built for two now it sounds distorted even in a single 12 box. I have not had time to test the other sub myself. I am just curious as to what causes this and is it repairable?
Rebuild coming soon
Wow.. top plate came off. Not sure if its fixable probaly not unless you get a new motor and a recone. Probably be cheaper to buy a new sub
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
well couldnt he just buy a motor and put the whole basket and cone assemply on it after removing the old top plate?
No cause you have to bolt the basket to the motor and that's under the spiders that are ca glued to the basket. So he would haive to cut out spiders and take out cone and coil to do it
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Double post fail sorry
Edited by dc98hoe
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
ahh ok. well thats a bit of a downer.
you just need a recone and a new motor...
but should get another recone for the other, to make sure they match up, and not 1 being old and 1 being new..atleast, thats what i would do
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
well buying a new motor and a recone, he might as well just buy a new sub.
still cheaper to buy the motor and recone, than it would be to buy a new sub... baskets are still a decent price LOL
Team DC Audio
