AA98hoe Posted October 26, 2011 Report Share Posted October 26, 2011 The power wire is hooked directly to battery terminal? Check fuse fuse holder. What size wire is it Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
traxxas101 Posted October 26, 2011 Author Report Share Posted October 26, 2011 Do you have any other amp you can hook up in the car to eliminate the amp as the problem? sadly no.. but before i sold him this amp i had it in my bed room hooked up to two 12" pioneers powered by a lawnmower battery of all things haha its been bangin for about 2 years no problems(: then i put it in his camaro and i get problems!?? Quote Link to comment Share on other sites More sharing options...
traxxas101 Posted October 26, 2011 Author Report Share Posted October 26, 2011 8 gauge 40amp fuse Quote Link to comment Share on other sites More sharing options...
poorfish88 Posted October 26, 2011 Report Share Posted October 26, 2011 Is it one of those Walmart Maxi fuses? If so those suck and I've seen them cause all kinds of trouble. Quote Link to comment Share on other sites More sharing options...
adreano17 Posted October 27, 2011 Report Share Posted October 27, 2011 1. Your alternator is weak, its time for an upgrade 2. if you are running a small gauge wire, then it may not be getting the sufficient amount of current. Quote Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow Link to comment Share on other sites More sharing options...
Kyblack76 Posted October 27, 2011 Report Share Posted October 27, 2011 Would a bad alternator cause it to play fine when it's OFF and cut out when it's RUNNING???.. Isn't that his issue??? Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Guest Posted October 27, 2011 Report Share Posted October 27, 2011 Would a bad alternator cause it to play fine when it's OFF and cut out when it's RUNNING???.. Isn't that his issue??? depends what the voltage is when the car is on. traxxas. have you even tried anything that i have said? you cant just ask questions then not diagnose it yourself. Quote Link to comment Share on other sites More sharing options...
traxxas101 Posted October 31, 2011 Author Report Share Posted October 31, 2011 Would a bad alternator cause it to play fine when it's OFF and cut out when it's RUNNING???.. Isn't that his issue??? depends what the voltage is when the car is on. traxxas. have you even tried anything that i have said? you cant just ask questions then not diagnose it yourself. hes running 13.8 soomething guys and i found out the power circuitry in the amp was bad and freaked out when it was fed 13.8 instead of just 12v from the batt so he got a new amp Quote Link to comment Share on other sites More sharing options...
