Wut up people,
Here is the deal I am doing my Civic's FLI Audio build and I have reached a point where I need to start adding the trimmings before I complete the main build. As far as trimmings go I am installing a volt meter, trunk lights, lights under each seat and lights on the mids/highs amp. So here are my questions:
Where do I wire the Volt Meter to get the best reading from my car when it's on with the engine running and when its on without the engine running?
What wire in the car should I hook the trunk lights up to so that they are on when the car is running and when I just have the key in the ignition listening to music?
Same question for the lights under the seat?
The lights for the mids and highs amps will be hooked up to the remote turn on at the amp so I have my answer for those.
All lights will have toggle switches on them just for my own craziness when ever I need to cut them off I like to know I can turn them off if need be.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
Wut up people,
I am going to be doing the same thing soon so what i did was get a relay and junction box post splitter and wire it so you could run everything to the splitter and it will turn on when your radio does.
Pic for your viewing
as far as the volt meter i would run it to the battery that you ran your amps to. although i am not to sure on the volt meter
Edited by KenC210
i could show better pics i am just getting ready for work... you could also use a switch from the junction post box to control the on and off like when its day and you dont need the extra drain on the battery. i also have a switch i could show more pics later
Wut up people,
What do you want the voltmeter to measure?
If you want to see alternator voltage, wire it to the front of your car (alternator or front battery).
If you want to see amplifier voltage, wire it to the amps (this will show you any voltage drop that occurs from the cable routing).
Trunk lights could also be hooked up to the remote turn on wire (with a relay). Or have a pin-switch conected to a relay that turns the lights on when the trunk is opened..?
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Wut up people,
That's a great idea but where can I get a junction box post splitter from and the relay?
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
I was thinking about a mercury switch for the trunk lights or wiring them to the wire that detects the trunk being opened but I still wanted a toggle switch for instances when I don't want them on at all. It sounds crazy but I have times when I want people to just the amps on with no other lights at all
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
Nevermind about the junction box I found one on Amazon but all I need are instruction on how I need to hook this up for everything to work with no issues. Detailed instructions would be great I am pretty good about following directions I just need to get this all hooked up so I can continue my install as planned.
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
  • Who's Online   2 Members, 0 Anonymous, 1263 Guests (See full list)
