vicjac1 Posted October 26, 2011 Report Posted October 26, 2011 Hello, New to the site so hope you guys can help. I am trying to run 4 powerbass 6.5 4xl and 2 powerbass L-3H Dome Tweeter into a Soundstream Tarantula TRX4.640. This is going in a crew cab silverado, so fronts are tweets with mids and rears are mids. All the speaker are 4ohms single voice coils @ 100 wts rms. The amp says it can run at 4ch at 100wts @ 4ohms. So I'm trying to figure how to wire it, do I need a component 2way passive crossover, just wire the tweets together with the mids? Please help Thanks.
OrionStang Posted October 26, 2011 Report Posted October 26, 2011 Put the tweeters on the front channels, one speaker per channel. Put the mids on the rear channels, two speakers per channel. The rear channels will see 2 ohms which is fine for that amp. You may need external crossovers if your h/u and amp don't cross where you need it. SMD Super Seller My Feedback Thread
ChevyBoy95 Posted October 26, 2011 Report Posted October 26, 2011 you will probably have to do 2 mids on 2 channels and each tweeter perchannel if you want to maintain left and right. But regardless i think you will loose front and rear separation which isnt a big deal anyway. Just do 2 mids per rear channel(2 in left channel, 2 in right channel), and 1 tweet per front channel(one left and one right). As long as your not watching movies i think it will sound fine, but if not use Y splitters on the input RCAs to eliminate front rear separation. someone correct me if this is off a little or a better way. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
vicjac1 Posted October 26, 2011 Author Report Posted October 26, 2011 Thanks 4 the replies. So, by an external you mean the type that comes with a component set up? With a y set up do I need 2 add another amp (2ch)? Thanks sorry 4 the stupid ?s.
