I didnt think that this fit in the Sketchup Bordom Thread, so i put it here.
The tutorial i saw for flared ports was ok, but didnt do what i wanted it to do, so i did some research, and now im posting a step by step (so that even a noob could do) tutorial on how to do flared ports.
First, start with a circle (mine was 10")
Then another smaller circle from the center (5" for mine)(to snap to the center hover over an endpoint in the circle and then move to the center)
Raise the inner circle (6") (push/pull tool)
(I seem to have lost the picture and dont feel like making another)
Delete all the surfaces (the parts that are colored) so that you only have a wireframe (select tool)
Draw the diameter with the line tool of the larger circle
Draw a line from where the diameter of the larger circle intersects with the lower small circle to the top small circle
Make an arc from the intersection of the diameter and the edge of the outer circle to the intercetion of the line we just made with the top small circle
Delete the surfaces, except for the arc
This part is more in detail
Select the follow me tool
2009 VW Rabbit 2-Door:
Pioneer AVH-X1600DVD
Kicker CX600.1 (Kicker "Certified" 638wrms@2ohm)
NVX VCW124 @2 Ohm, ~1.25 ft^3 Sealed box
Stock Doors; (4) 6.5's, (2) 4's, (4) 1" Tweets
Owner/Founder of RT Photography
Canon Traitor who moved to Fujifilm
Select the surface of the arc
Follow the outer circle until the flare is completed.
Look at the bottom and delete everything except for the top small circle, the big circle, and the flare itself
Selct the flare, and circles (triple click with select tool) and make the flare a group (Command + G on Apples, CTRL + G on windows (i may be wrong))
make a circle on the top of the flair (see above on how to snap to center)
Extend the circle (push/pull) (any length)
Delete the two circular surfaces to get this:
Copy the first flare (CTRL + C) (Command + C)
Paste (CTRL + V) (Command + V)
Flip 2nd flair group with move (Picture22.png) tool
Place on top using move tool
Select the whole thing and make a group
Apply whatever you want!!
There you go, Have fun, tell me if you have any issues!!!
the fun part is fitting it to your box ;)
edit: this tutorial doesnt account for the thickness of the material of the port... im too lazy to do it.
Edited by +ZER0Hz+
don't you just use scale tool to scale it to the opening
"IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Powermaster S3400 & D3100
Iraggi 300a alt
SecondSkin - totally dead
Knu wire
for some reason ive always had trouble with the scale tool... id rather just build the box with the opening, then build a port for it....
Heres the box im looking at building:
hahah thread jack my own thread....
Edited by +ZER0Hz+
I've always wondered whats the purpose of the square on sketchup?
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Iraggi 300a alt
Knu wire
probably for if you line it up with the square it will show the scale to get a guesstamate of the size so you can see approx. how big an object is
edit: i wanna see someone try the port, post up pics! :D
Edited by +ZER0Hz+
I deleted Sketchup long time ago...but yall made me wanna download it again, there should be a stickied post where we post out sketchup boredness...
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
