Numatik's Bagged 2004 Silverado
Just replaced the water pump and the squeal is still there.....
New belt, new tensioner, new idler pulley, sent alt for testing and some new parts, new water pump.... When AC is off it still squeals, sometimes the truck will go a day or 2 without a squeal, but yesterday it didnt squeal at all then turned it off. I went out there this morning and without even turning the wheel to allow the power steering to engage it started squealing. Im stumped......... Last thing to check is perfect alignemnt with a caliper tool but im gonna need to buy one. Im about to send this to a shop but I dont think theyl find it either and charge me by the hour trying everything that iv already tested
Gary 'Numatik' Eberle
West Sacramento, California
Vehicle build log (1) 'Aayla' Numatik's one and only, bodydropped pasted the doors Chevy S-20 Ext-Ext cab. This project ended after a horrible horrible motorcycle accident. There are so many mods it would fill an entire page in my sig. Check it out if you have A LOT of time to kill. http://www.stevemeadedesigns.com/board/topic/39785-numatiks-doored-s-20-bodydropped-on-doors-ext-ext-cab-10-subs-full-frame-build/?hl=%20numatik#39;s
Vehicle build log (2) 'Snow White' Daily/showstopper 2004 Chevy Silverado
Lays on 22s soon for 26s to run a beefy tire on 4s (4) 5gal tanks, (3)AZOB2 pumps, Slam digital stealth two speed valves with 16 solenoids, Slam SS bags all around, ART upper and lower arms, KP Components 6-link, KP Components watts link, Panther juice 6 22s, Spikes EVERYWHERE. 3,600WRMS total, (5) Kicker amps, (2) L7 15s under raised back seats, 15" screen molded to dash, 36 speakers total all Mb Quartz and Fosgate. Fiberglass console with removable face plates and arm rests, flushed speakers, lots of toggle switches, Playstation 2, rear view camera, Suede and leather seats, suede headliner, Dakota Digital air gauges, voltage gauges, and current draw gauges. (2) XS Power 4800 batteries, Whole truck is flat black and white and the
ENTIRE truck is fully pin striped by TJ Pagano here in Sacramento.
http://www.stevemeadedesigns.com/board/topic/123328-numatiks-bagged-2004-silverado/
"What doesn't kill you makes you stronger. I am proof" - Numatik
Update:
I just spoke with the previous owner of the truck. He did not know who did the band aid fix of the bottom of the fuel cell, but did point out someone who did do the jb weld vent tube. He wanted to appologise about the gas tank because some locals had joked it being dumped on me. He didnt understand because he didnt know it was there.
As far as the center sub, he did jb weld the ring because it rattled, and since it was inverted we suspect that some jb weld went down bonding the woofer to the center console. Im gonna pull the screws again and gently work at it , but if I cant finesse it out im gonna do what I posted earlier and cut the entire basket off and cut along the woofer ring inbetween the sub and center console so a new woofer or filler can go in the same hole.
Another big update,
The power steering pump is NOT the factory one. It is from a 04 silverado 2500, they swapped it to work with the hydroboost brake system. it was brought up in my other thread that the power steering pulley may need to be shimmed in or out to be in perfect alignment, so im gonna need to use a caliper and measure them all. Also since its a different pump, he said the other belt that I originally removed was a little bit shorter. I also told him that since it was a spring tensioner and the belt was tight, that I didnt think even a shorter belt would matter because the tensioner would still pull just as hard.
good to here your back on your feet!!
"Audio is not a hobby it's a lifestyle"
_____________________________Refs_1_Refs_2_____________________________
My alt went out today, fucking awesome. and even worse I had to goto the ER today, I had a sack of blood (forgot what its called) build up behind my leg I just had surgery on. I bent my leg in such a way that it made it burst, busting open the incision soaking my entire pant leg and sock, and inside of shoe in blood. I lost almost a pint of blood it was a fucking mess. Ruined one of my favorite pairs of pants and a white towel also ruined (and now a shop rag). Between this and my alt going out its been one hell of a fucking day
You need to slow down man. You seem very motivated to get. Back to work on the truck. But you should worry bout yourself first. The truck will still be there when your back to 100%.
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
Im trying but your right. But I have only been doing small tasks, nothing to major and little bits at a time. I just get so frustrated sitting on the couch and not being able to do anything, and I am soooo behind on progress I feel like im never gonna finish this thing. I know its cause of the million medical problems I have, but I just need to keep working as much as I can. I have sooooo much work to do I cant even explain :unknw:
Awesome work
Found both threads, right on bro!
Yea I know how you feel. But the truck still looks good and cant wait to see updates. After you have heeled fully. Lol.
the blue flames look sick
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
