98 tahoe pass door problem?
can you lock the door manually using the passenger door switch? when you hit the lock on the drivers side does it unlock the passenger side too?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I think the installer just wired wrong or something because the truck works perfect with out the switch, like mentioned in previous post I'm also shocked it worked without the switch?
thats why Im asking if it works fine by using both the driver and passenger switches. Im wondering if he grabbed the wires for the motors individually instead of grabbing at the switch or relay .
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
for some reason i can't, i press the lock button and nothing happens, window switch works perfect
Pretty sure if you grab them at relays its down line from the switch before the actuators
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
It doesnt work with driver and passenger connected
when you push the lock button on which door? pass or driver
when you push the drivers side lock what happens
when you push the pass side lock what happens.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
pressed the lock on both doors and nothing happened
have you checked your fuses.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
sound to me like it was not installed right and the wire to the door trigger or lock wire is backwards....i did the same thing on my passport trying to follow the old security system wire splice's...if im right its no big deal pop the kick panel off and revers the wires...make them do it tho another thing is on the GM you have to dbl tap the key fobs on there are 2 dif wires that will lock the doors & unlock them could be that as well
hope im right and it that easy..lol G.L
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
