98 tahoe pass door problem?
Sounds like bad wire or switch the alarm is down line from switch and activates relays. If you connect switch something is wrong on lock side. Not sure haven't done a my alarm for a year I forget lol a good installer would pop off both switches and test with powerprobe. Pretty sure switch rest at ground then switches to pos for lock and unlock so you have to check for both
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
if it doesnt lock with the door swtich itself its not the install. well it oculd be. if he tried to wire using the module and had to cut the wires for the five wire. I dont know why he'd do this. but it also should not work with a swtich unplugged. I could go out to my truck right now and pull either switch off and they would not lock. Id take it back to him and say WTF did you do because this isnt right.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
have you checked your fuses.
i see the problem i replaced the fuse then locked and unlocked manually on the drivers switch then tried it on the passenger and it only locked but when i tried to unlock it i heard a pop and it was the fuse again?
hes got something grounded out. take it back to him. make him fix it.
I have no idea how he's managed to get the doors to function independently. Yours should be the exact same as mine. I grabbed one set of wires at the switch itself. If I want to unlock independently I set the double pulse up.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
What year is your truck n8? Pretty sure 5 wire was only up to 95. That were you had to pull driver side dash speaker and cut the 5 wires in the harness and drop wires to relays
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
ok I'm going to take it to him tomorrow, and what do you mean by grounded out somewhere, sorry im a noob to alarms.
mines a 98 too. I know I didnt have to do a five wire in mine. I have no idea what this guy was doing to be honest lol. lock/unlcok is one of the easiest ones to do for an alarm I feel.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i see the problem i replaced the fuse then locked and unlocked manually on the drivers switch then tried it on the passenger and it only locked but when i tried to unlock it i heard a pop and it was the fuse again? He wired passenger door wrong.. make them fix
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
arent the locks on that year + trigger?
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Especially our years you pull the relays down t tap the wires hook to blue green wires on most dei alarms done
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
