98 tahoe pass door problem?
mines a 98 too. I know I didnt have to do a five wire in mine. I have no idea what this guy was doing to be honest lol. lock/unlcok is one of the easiest ones to do for an alarm I feel.
plus its the first time this has happened because hes done 3 of my trucks excluding the 98 tahoe and they've all been working perfect for the past year or two
Especially our years you pull the relays down t tap the wires hook to blue green wires on most dei alarms done
exactly it took me longer to bench prep it than to do the alarm including the hood pins and all the sirens.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
looks like 5 wire. i bet he wired the 5 wire relays wrong. what alarm is it
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
It should not need a five wire.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
the 2 door hoe's are 5 wire the 4 door's are + trigger
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
That's what I thought so he has the motor and switch wires backwards on on of the relays. Easy mistake easy fix. And I posted wrong info early you are right t money pos trigger white and blue wires at relay pack
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Mu bad
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Pos phne sorry
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
