stinky coils
qcbangin
Chances are you're clipping the signal to that subs. And if your sun is not moving easily with rated power, the sub may be too stiff and not enough airflow through vents to cool the coil
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
just checked the coil yesterday, and didn't see any discoloration
i've tried to go through just about every setting in the head unit. the highest i've gone on the volume is 42, but generally i don't go over 30. it has been wired to 1ohm for about a week now, and it just started getting stinky yesterday. besides the sub volume, does everything else sound about right? could an air leak somewhere in the box cause this problem?
is the coil starting to burn out what colour is it
Could be glue smell? But then its not always visible inside a build sub to see the coil burn
Take a pic of the setting...
does the other settings sound right? the gain 1/3, low pass 1/3, bass 0, and subsonic 1/3?
Setting "sounding right" and settings "being right" are 2 different things. Ive changed my settings a few times. Each with my dd-1, and my scope (before I had the dd-1) and it was different settings each time. An example is when I changed my head unit. You need to get someone in the area who can help you set em properly so you dont smoke you equipment.
Rebuild Log with the SMD
CURRENT..
Honda Accord Coupe
Porsche Cayenne S
Lexus CT200
Lexus ES300 (sold)
99 Lexus RX 300 (sold)
ADDING
Honda - Hertz setup, more to come
Porsche - Fi BL, XS Power, more to come
coming soon..
peep the old rebuild log of the Lexus RX
ya i had no smell mine is only like 3 months old. and never once smelled. same exact sub.
Also whats your box tuned to?
CURRENT..
Honda Accord Coupe
Porsche Cayenne S
Lexus CT200
Lexus ES300 (sold)
ADDING
coming soon..
  • Who's Online   1 Member, 0 Anonymous, 1292 Guests (See full list)
