I run my 2 hdc3 18's in 10 cubes with 140 square inches of port btw. Sounds phenomenal.
For that 15, you could get away with 3.75-4.25 cubes with ~55-~60 square inches of port.
yeah i screwed up when i design it and calulated the port wrong, noob mistake haha
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
I'd make the port bigger which will help to lose some box volume. I've had very good luck with 4.25-4.5net with AQ/DD subs. 16^2 port area and up to 20^2 for daily set ups...
As stated the sub is loading off the trunk lid, so once you open the trunk you lose that loading wall.
Posted (edited)
Box is only 5 cubes? I would of made it around 6. And only 10 sq in of port? Wayyyy to small. Definitely sounds like a box problem. I would do around a 6 cube box, with around 15-16 sq inch's of port.
That's still chokingly small. I would say ~60 sq in of port as a minimum (I'm using 73 for my current box)
What's your port shape?
I didn't mean it like total area of port, 16sq in per cube. Sorry i didn't explain it better! haha.
I built a box for a XL 18, Has 6.06 after, and 18 sq in per cube with 114 sq in of port area. Just to give you a rough idea though.
Oh, my bad. I thought you meant total LOL.
In that case stick to 12-16 sq in per cubic foot. I like to err towards the larger side of a port when possible since it gets louder. But also be aware that with a larger port - the sub will unload faster when it drops below the tuning point
Edited by SnowDrifter
yeah im actually making a new box right now, and snowdrifter that alright haha, i was assuming u ment total
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
  • Who's Online   0 Members, 0 Anonymous, 1060 Guests (See full list)
