everytime my sub hits ( 9515 DD) its not clean,well from inside of the car its sounds nice, but when you open the trunk it sounds like its trying to punch itself out. my Lpf is at 25 and high pass is around 70, gain 3/4 , bass boost off. i'm running on an AQ 2200, so it shouldn't be overpowering so i am just confused
Why is it doing this? i really don't want to wreck the woofer any info would be appreciate. THANK YOU!
Edited by Stee-Z
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
keep the trunk closed, yes it's that simple. Assuming you're rear firing the sub is loading off the back wall of the trunk which helps to control the cone. Opening the trunk is causing the sub to unload/lose control
5 ft3 at 30hz but i messed up and only gave it 10 sq in. of port , when i need like 16, and the subs facing up :/
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
u mean your subsonic is at 25 and your low pass is at 70. correct?
haha yeah sorry, tryingto multitask
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
so theres no way to fix it, just keep the trunk closed and turn it off if i open trunk correct? or keep at lower volume
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
Box is only 5 cubes? I would of made it around 6. And only 10 sq in of port? Wayyyy to small. Definitely sounds like a box problem. I would do around a 6 cube box, with around 15-16 sq inch's of port.
Well yeah, and the fact your opening the trunk, its going straight out. But still, box is way to small.
Also, I would try to set your subsonic, maybe 2-3 hz below your box tuning. Just to play it safe too.
Edited by Katt
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
yeah thats how smart i was being the nite i design it.. typed the calculation into the calculator wrong lol, never second guessed it. It's choking it off
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
  • Who's Online   0 Members, 0 Anonymous, 820 Guests (See full list)
