Hey guys, the current box is total crap, it has something like 3"per foot on port area so as you could imagine, doesn't do anything for the subs.
This is going in my 1991 Mazda 323 hatch so the boot area s tiny and I don't want to take out any trim panels unless I have to. this is what I have come up with for a new box, the dimensions are the max I can do. I know there is still a shortage of port area but I don't want the tuning to rise to much more than this. the subs are two pioneer ts-w308d4 12"subs. running at 2 ohms off a soundstream stl-1200d.
is there anything i can do to this box design to make it preform better?
this is the first time ive uploaded pics so i hope they work. I will embarrass myself and upload a pic of my current box if anyone would like to see it <_<
edit: links didnt work
Edited by pinkoP35
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Those are the specs for your current box? Yikes.....
Big 3 with Yellow Top
yup :S I built it before i got the subs and a brain....
PSN: Rcp_soundz
specs of the new box i want to make
Edited by pinkoP35
PSN: Rcp_soundz
Okay so ive changed my mind after playing around in the car with the trim panels. I took one pannel off that now looks like it was installed by the previous owner, I can now go 500mm deep and 950mm wide. Thats a lot more space compared to my last design. what would be better do you think? a slot port down one side? and the two subs put really close together on the other. or the same design as last time, only bigger and lower tuned with more port?
cheers,
PSN: Rcp_soundz
3 cubic feet and a single 6" Aeroport it´s a kickass box for a pair of those subs ;)
would two 3" pvc tubes be okay? i cant get my hands on any 6"stuff
PSN: Rcp_soundz
partsexpress.com has 6" aeroports
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
No, it wouldn´t be good, i´ve tested one big port vs multiple smaller ports before and i always get louder with a single port, try finding 6" PVC tube, if not, then use 2 4" pvc ports...
