heres my deal, had a cheapo system with 8 gauge power wire, factory alternator and battery (97 tbird)
just upgraded
2 RE audio SRX 15s dual 2 ohm 300rms / 600peak they are in sealed box(the right amount of space)
alpine mrx-m100 mono amp - 2ohm = 1087watts is what the certificate says
I have the subs wired in series to run a 2 ohm load on the amp and the amp gain is at about 3/4
not sure where to put the bass eq on the amp at but i think it is at +6 (0 to +12), the crossover frequency is at 50hz and the subsonic filter is at 25 or 30
I am not sure about how to set the subsonic filter or bass eq because my last amp didnt have that
but when i turn up my stereo to a good level then turn my remote amp knob up and get past 1/2 way and it sounds like the amp/subs are cutting out then i back it off and the bass comes back, what could be wrong? it doesnt sound distorted and it did this when i was originally setting the gain
Turn your gain down for starters. Sub sonic filter sounds about right. Set the other at 80 hertz.
2012 Nissan Altima SL
DC M2 Lvl 3 12" with AR cone
DC 1.2K Amp
Kicker Sum8
Kicker 4 Gauge amp kit
XS Power D2700
1.5 Cubic ft net tuned to 38Hz
you need 4 gauge on the amp. 8 gauge is too small. put the bass eq to 0, and never move it from there. gain also seems to be too high.
Also leave the bass boost off. Can't tell you where the gain should be because you nee to scope it. Maybe 1/4 would be good but can't say for sure
DC 1.2K Amp
Kicker Sum8
XS Power D2700
Yeah sounds like you have your settings too high.I would try to find someone with a DD-1 or a scope to set everything for you.
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
I dont plan on having this car much longer so dont want to go all out, (rewire, battery, alt) was hoping it was my settings and i was thinking about investing in a DD-1 but I dont think I would use it much since im not into changing my system much or competing its just for driving around and bumping some
so is this just something built into newer amps that shuts it down because it senses something? my previous amp was a 15 yr old mrv-1000 and it didnt shut off
it will keep shutting off unless you change something. you arent running large enough wire and your settings are all fucked up.
  • Who's Online   0 Members, 0 Anonymous, 699 Guests (See full list)
