Sid420 Posted November 1, 2011 Report Posted November 1, 2011 Well I have a plye. Yeah I know. I didn't buy it my friend gave Be it to me. But I hot about two weeks of bumbing and then it went out. So I took it out and checked the coils and they were both readin 4.0??? But when I play it the cone does not move at all and sounds like the coil is working fine. Don't know what to do?
corey0928 Posted November 1, 2011 Report Posted November 1, 2011 Check all the connections, make sure the sub is hooked up properly. Make sure the output channel on your amp is working
STEvil Posted November 1, 2011 Report Posted November 1, 2011 make sure the cone is still connected to the coil. The joint on the bottom of the cone may have broken loose. If its broken you might be able to epoxy it (24 hour epoxy, LOTS) and be ok.... for a while. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Sid420 Posted November 1, 2011 Author Report Posted November 1, 2011 make sure the cone is still connected to the coil. The joint on the bottom of the cone may have broken loose. If its broken you might be able to epoxy it (24 hour epoxy, LOTS) and be ok.... for a while. how do i take it apart the basket is chrome and it seems like the basket is glued to the coil container...
STEvil Posted November 1, 2011 Report Posted November 1, 2011 cone is abouve the coil, you should be able to push on the back of the cone and see if it moves while the spider and coil stay (mostly) stationary. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
