Sactownbully84 Posted November 2, 2011 Report Posted November 2, 2011 Take the back seats out cushion and all....probably the rear deck too..... Quote 2001 Grand AM Pioneer UB4000 HU Tsunami / Monster Wire's DC POWER INC 260SP ALT w/ XS Power VCM BIG 3 All 1/0 Monster 400 + YT Under Hood Stinger SPV70 x2 in Trunk 4x SA-10's On There Way soon i hope SS XXX-4000D @ .7ohm 3K+ RF Power 4x6's & 6x9's Monsoon Powered PG TL22 Line Driver 148.7db @ 35-45hz sweep w/ 12" BTL
melb-bass Posted November 2, 2011 Report Posted November 2, 2011 i had a similar issue, the way i solved it was to take off the top peice and put box in the trunk, then screw down the top peice in the trunk. prblem is that you cant seal the top permanently with glue or caulk, so i used a rubber lining between the top peice and the box. Hope that makes sense Quote
loganberry Posted November 2, 2011 Report Posted November 2, 2011 Take off the trunk lid or the latch it locks into. The latch itself gives you alot more room to move the box around and adjust. I know I've had to do that a few times on customers who measure their Max dimensions in the trunk but forget about getting it in the trunk Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
fmedina Posted November 2, 2011 Author Report Posted November 2, 2011 i had a similar issue, the way i solved it was to take off the top peice and put box in the trunk, then screw down the top peice in the trunk.prblem is that you cant seal the top permanently with glue or caulk, so i used a rubber lining between the top peice and the box.Hope that makes sense good idea but i want to make sure my box is sealed up. Take off the trunk lid or the latch it locks into. The latch itself gives you alot more room to move the box around and adjust. I know I've had to do that a few times on customers who measure their Max dimensions in the trunk but forget about getting it in the trunk i thought about removing the latch but i think it still wont fit. im about to do some re-measuring and big a second box and see how it goes Quote
fmedina Posted November 2, 2011 Author Report Posted November 2, 2011 (edited) ok so can someone please help me out with a design? this is what i go so far... sub up port back powered by a brz1200 Edited November 2, 2011 by fmedina Quote
412 CVX Posted November 3, 2011 Report Posted November 3, 2011 do you want a sketchup model? i think the specs look good. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
fmedina Posted November 3, 2011 Author Report Posted November 3, 2011 do you want a sketchup model? i think the specs look good. Sure if you don't mind! Quote
