Take the back seats out cushion and all....probably the rear deck too.....
2001 Grand AM
Pioneer UB4000 HU
Tsunami / Monster Wire's
DC POWER INC 260SP ALT w/ XS Power VCM
BIG 3 All 1/0 Monster 400 + YT Under Hood
Stinger SPV70 x2 in Trunk
4x SA-10's On There Way soon i hope
SS XXX-4000D @ .7ohm 3K+
RF Power 4x6's & 6x9's Monsoon Powered
PG TL22 Line Driver
148.7db @ 35-45hz sweep w/ 12" BTL
i had a similar issue, the way i solved it was to take off the top peice and put box in the trunk, then screw down the top peice in the trunk.
prblem is that you cant seal the top permanently with glue or caulk, so i used a rubber lining between the top peice and the box.
Hope that makes sense
Take off the trunk lid or the latch it locks into. The latch itself gives you alot more room to move the box around and adjust. I know I've had to do that a few times on customers who measure their Max dimensions in the trunk but forget about getting it in the trunk
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
i had a similar issue, the way i solved it was to take off the top peice and put box in the trunk, then screw down the top peice in the trunk.prblem is that you cant seal the top permanently with glue or caulk, so i used a rubber lining between the top peice and the box.Hope that makes sense
good idea but i want to make sure my box is sealed up.
i thought about removing the latch but i think it still wont fit. im about to do some re-measuring and big a second box and see how it goes
ok so can someone please help me out with a design? this is what i go so far...
sub up port back powered by a brz1200
Edited by fmedina
  • Who's Online   0 Members, 0 Anonymous, 3971 Guests (See full list)
