Coolbeans Posted November 2, 2011 Report Posted November 2, 2011 (edited) Building a JL W7 daily box SPECS: 3.27cu.ft box tuned to 32.61Hz with 15.13port area per foot theres 1in dowels for bracing anyway does this look about right, as far as proper port length for tuning Edited November 2, 2011 by Coolbeans Quote
412 CVX Posted November 2, 2011 Report Posted November 2, 2011 unless you're doing a 15" W7 which i don't think exists, 3 cubes seems like a little much. also if you moved the vertical dowel over a couple inches, it might be more effective. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
soundcheck11 Posted November 2, 2011 Report Posted November 2, 2011 1.7 ported is roughly what you need for 12-13.5" w7 Quote
soundcheck11 Posted November 2, 2011 Report Posted November 2, 2011 13w7 is 2.375cuft ported for 30hz 12w7 is 1.75cuft ported for 32hz 10w7 is 1.5cuft ported for 32hz 8w7 is 1.0cuft ported for 32hz i have 4 12w7's they play good in an 8cuft box tuned to around 30hz. I had 2 before that and it sounded amazing in just under a 4cuft sealed box. So, id suggest getting your box very close to these specs and it will sound pretty damn good. Good luck Quote
RAM_Designs Posted November 2, 2011 Report Posted November 2, 2011 If you're running limited power to a 13W7, that box will work just fine. Don't expect to be able to put a whole lot of power to it though. Quote Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
