6berry's UBL
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
plastidip FTW!
Build Thread
UBL
1948 Plymouth
the roundovers i put in started to lift up on one of the edges so i screwed them down and fiberglassed them so they were nice and solid.
and while i was inside the box i put some bondo down on the bottom of the box since it was kinda rough from fiberglass
and i retinted the taillights because they were starting to fade and i wanted them darker
Build Thread
UBL
1948 Plymouth
started to work on a trim panel to clean up the trunk a bit. i still need to get my 3500 or find measurements for one to do the hole for the bottom
Build Thread
UBL
1948 Plymouth
finsihed the fiberglass pods for the rear speakers today. ill post a pic of them in the car tomorrow because it was already dark out
Build Thread
UBL
1948 Plymouth
heres the finished product in the car. i thought i posted i posted it but i guess not
Build Thread
UBL
1948 Plymouth
did some more work on the trim panel for the rear of the box. i cut out the hole for the bc3500, cut out where the buss bars are, and made spacers to screw it into and did a little bit of trimming to make it fit right.
trimmed for the rca's and cut where the buss bars are. ill probably end up making a separate cover for the buss bars.
and heres how i made the spacers for it. i took some scrap of the 1/4 im using for the trim panel and glued it to some 1x3. it was too dark to take pics once i was done so ill post the finished pics tomorrow
Build Thread
UBL
1948 Plymouth
heres the blocks i used to screw the trim panel to
and heres the trim panel all screwed in. look at that little baby rockford amp in the hole for the BC3500. i still need to think of something to cover the buss bars.
Build Thread
UBL
1948 Plymouth
pulled the port off yesterday to switch the sub back over to the other chamber so both subs are in the same chamber again. while i had the port out i finally got terminals for the speaker wire and cleaned up the wiring in there and i pulled the magnet boots off for that extra .1 db
all terminals were soldered like always
will be getting some leds soon to light it up in there
also i got my DD1 today and it is so much louder than before! i used to only have my headunit up to 45 but found out im clip free at 62 out of 62 so i set my gains at 60. mids and highs are so much louder and the bass is on a whole other level. thanks steve meade and tony D for making such an awesome product!
Build Thread
UBL
1948 Plymouth
