sub direction in ext. cab
jballin2010
quick question..how much room did you leave on the side of your box? and i agree 6 inch port wont be near enough for 2 18's?
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
around 4" on both sides and im going to run two ports (two 10"). . . or should i do three for more area?
If your not over window line.... I highly doubt you have 13 cubes...
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
that was my thoughts.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
its not a matter of thoughts... it math 56.5x19x27=28984.5.. 28984.5/1728=16.77.. after subtracting the 3/4 circumference you come out to 14.2ish cuft
i dont think you are taking into account port displacement. or driver displacement. We are saying that because we have the same truck.
my wall is 57 wide by 35 high by 27 deep. after port and driver displacement I end up with around 17.5 cubes.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
ok if those are your external dimensions you do end up at 14.2
however .24 per driver for displacement and for the tuning of 30hz you need 4 6 inch aeros at 18 inches per. Im not even going to factor in bracing since those nice big flat panels will flex to hell and back with a single layer. btw that gives you about 12.5 cubes
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
