Shakespeares Posted November 3, 2011 Report Posted November 3, 2011 I'm relatively new into beginning builds, and for my first install, I built a box 17.5*8.5*17(l*w*h*) for a Kicker CVR 10". Then I added in an Autotek M1600.2. 4awg to positive and ground, and double layered 12awg from amp to sub(temporary until I get more wire). Sub is bridged at 4ohm, and it's loud inside, but It doesn't seem to be as loud as I'd imagine it to be. A friend of mine has maybe two hundred watts more and is heard throughout the parking lot, whereas mine barely vibrates on the outside. Box is behind the seats of a 99 Chevy 2500 Reg. cab. With this basic setup, am I able to get any louder or notice any flex? At most my mirror will vibrate and blur, but no real movement. Also, would 64*8.5*17 work for 4 Kicker CVR 12"s? Thanks in advance, JM.
MrSkippyJ Posted November 3, 2011 Report Posted November 3, 2011 is your box sealed or ported? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Shakespeares Posted November 3, 2011 Author Report Posted November 3, 2011 Sealed. I was debating on if porting would do the trick or not.
Azagtoth502 Posted November 3, 2011 Report Posted November 3, 2011 Can't speak for your setup, but ported can make a big difference. pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
95legwagon Posted November 3, 2011 Report Posted November 3, 2011 Can't speak for your setup, but ported can make a big difference. /\ ding ding ding lol ported is wayyyyy louder than sealed in any situation imo.... you move more air that way and that what causes flex ..... i have 1 12" sub running off 600w rms (if that) and my car definitly vibrates alot and you can hear me coming..... ported is the way to go. some say you lose alot of SQ with a ported box but i dont think so really.... just my 2 cents..... p.s. heres so you can find out the difference in box size for what you need . Straight from kicker Min Rec Sealed Box Volume (CU. FT.) - 1.8 Max Rec Sealed Box Volume. (CU. FT.) - 5.2Min Rec Vented Box Volume (CU. Ft.)** _3.0 Max Rec Vented Box Volume (CU. Ft.)** _ 5.0 ** excluding port volume hope this helps i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
Shakespeares Posted November 3, 2011 Author Report Posted November 3, 2011 I think that is actually the 15" specifications. I have checked their site a bit. I appreciate it, I'll try to port and see how it does.
