curtdakota Posted November 6, 2011 Report Share Posted November 6, 2011 (edited) ok i plan on using a http://www.kinetikpower.com/2009/product.asp?P=KIPS12-80&C=2 the kinetic 80amp power supply and a small kinetic battery to run a 4 channel amp in my room, i probably gonna be a mb quart dsc4125 cause i have an extra one laying around, but my question is instead of using a head unit, can i just use a ipod using a 3.5mm to rca adapter? or would the sound quality be bad enough to not do it that way. Edited November 6, 2011 by curtdakota Quote Link to comment Share on other sites More sharing options...
chronic2001 Posted November 6, 2011 Report Share Posted November 6, 2011 I don't care for iPod quality. Mp3 or USB for me. Quote Pioneer deh-8300UB 6- Image Dynamics CSX6.5v2 4-Image Dynamics XS-28 tweeters 4-Sundown Audio sa8v2's 1-Sundown Audio SAX-200.4 1-Sundown Audio SAX-1200d 1-Mechman 270a alternator 1-XS Power D3400 under hood Second Skin Damplifier Pro Deadener Kicker & Knukoncept 1/0 wiring Big 3 upgrade Link to comment Share on other sites More sharing options...
dohckiller808 Posted November 6, 2011 Report Share Posted November 6, 2011 go for it. its fine. when a system is giving loop noise i use an ipod in the decks place to determine if the noise is coming from the deck or the amp. Quote Link to comment Share on other sites More sharing options...
miniSPLlancer Posted November 6, 2011 Report Share Posted November 6, 2011 Yes you can Quote 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals Link to comment Share on other sites More sharing options...
Katt Posted November 6, 2011 Report Share Posted November 6, 2011 Yeah, but what you can do is, Get a DD1, play a track transfered to the ipod, and when it clips back it down some, and then lock the volume from the settings. And then hook the iPod to the amp, Play the track, and turn it to where its locked ( not clipped part ) and then set your gain. And you can use your iPod. Quote *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch* Link to comment Share on other sites More sharing options...
VIPmeetSPL Posted November 6, 2011 Report Share Posted November 6, 2011 I have a cheap hesdunit if you'd like auxiliary and USB in front Quote Link to comment Share on other sites More sharing options...
curtdakota Posted November 6, 2011 Author Report Share Posted November 6, 2011 sweet guys, answered my question, i just wanted a cheaper way of doing it rather then buying a head unit, its cheaper to use an ipod i already have. and besides, considering im considering this option in the first place, im not really needing super SQ here, i just want to be able to have a loud, bass heavy setup for my room, utilizing most of the stuff i already have. Quote Link to comment Share on other sites More sharing options...
CVLover Posted November 6, 2011 Report Share Posted November 6, 2011 sweet guys, answered my question, i just wanted a cheaper way of doing it rather then buying a head unit, its cheaper to use an ipod i already have. and besides, considering im considering this option in the first place, im not really needing super SQ here, i just want to be able to have a loud, bass heavy setup for my room, utilizing most of the stuff i already have. you can also use and home amp with preout. or sub out. to the car amp:D tats what im doing:D and works really well.. only thing is that my amp uses so much electricity that my 3 power supplys makes it shut off ;((( mor powaaa Quote Cerwin Vega <3 . When Bass Counts! Link to comment Share on other sites More sharing options...
Guest Posted November 6, 2011 Report Share Posted November 6, 2011 you can use an ipod and a 3.5mm cable. but you'll just have to turn the gain way the fuck up cause theres barely any signal coming out of that headphone jack. Quote Link to comment Share on other sites More sharing options...
