howelr Posted November 6, 2011 Report Posted November 6, 2011 So i have a 97 Honda with im not sure the amperage off the alternator its either 85 or 95 but my question is would i be able to run 2 amps off it? i have a 10" L7 with an alpine mrp-500 right now. should i upgrade amps for the sub? and would i be able to put in another amp for the door speakers, also Kicker KS series 6.5's so not terribly large only maybe 50 rms per. i dont have a ton of money for the amps maybe 250 max right now but Christmas is coming up and the family is asking for ideas
danterakin Posted November 8, 2011 Report Posted November 8, 2011 I put in 4 8s with a 800+wrms amp with stock electrical and her 2000 civic sedan does well. It does have minor diming on hard instant bass notes but it doesn't hurt much, like her voltage drop goes to 11.8 volts which ain't too bad. But make sure you do big 3 upgrade because that helped a lot. I just used 4 gauge for the big 3 since everything was all short distances. Also had a run of 4 gauge going to the back. So to answer your question, yes you should be fine to handle your 500 watt alpine along with a 4channel amp. 1984 Bronco Setup 2 15" Kicker L7's 1 Hifonics Brutus 2608D 1 PDX-4.150 Kenwood x792 Deck 2 114Ah Discover Batteries 0 Gauge Everywhere 200 H/O Alt 2 Piece of shit 6.5 Lanzars Front Doors 2 Alpine Type R Coxials 4 Water Proof 6.5" Speakers Outside Car 2 4" Sound Stream for Bumper Speakers 2 6x9 Alpine Type 6 Coaxial Rear Speakers 1999 Honda Accord Coupe V6 1 Kenwood KDC-X692 Deck 2 Alpine Type S 6.5 in Doors 2 Alpine Type R 6x9" in Rear Deck 2 AQ HDC3 10's Dual 1's 2 C&D Technologies 75 Ah Batteries 4/0 Front to Rear 0 Gauge All Around Big 3 Included 1 American Bass 500.1 1 PPI ProArt A404 Old School 4-Channel Amp SOON: 300 Amp Excessive Amperage Alternator
howelr Posted November 8, 2011 Author Report Posted November 8, 2011 I put in 4 8s with a 800+wrms amp with stock electrical and her 2000 civic sedan does well. It does have minor diming on hard instant bass notes but it doesn't hurt much, like her voltage drop goes to 11.8 volts which ain't too bad. But make sure you do big 3 upgrade because that helped a lot. I just used 4 gauge for the big 3 since everything was all short distances. Also had a run of 4 gauge going to the back. So to answer your question, yes you should be fine to handle your 500 watt alpine along with a 4channel amp. alright sounds good, should i upgrade the sub amp? it rms's at 600 but im not sure what an extra 1-200 watts will get me sound wise
danterakin Posted November 10, 2011 Report Posted November 10, 2011 alright sounds good, should i upgrade the sub amp? it rms's at 600 but im not sure what an extra 1-200 watts will get me sound wise I think the MRP-500 would be good enough because that L7 10inch probably likes the power it's seeing. My 15" L7's seems to work really hard for near 1k rms. If you do come across a bigger amp, go for it, its never a bad idea to overpower your sub but just keep an eye on your electrical. 1984 Bronco Setup 2 15" Kicker L7's 1 Hifonics Brutus 2608D 1 PDX-4.150 Kenwood x792 Deck 2 114Ah Discover Batteries 0 Gauge Everywhere 200 H/O Alt 2 Piece of shit 6.5 Lanzars Front Doors 2 Alpine Type R Coxials 4 Water Proof 6.5" Speakers Outside Car 2 4" Sound Stream for Bumper Speakers 2 6x9 Alpine Type 6 Coaxial Rear Speakers 1999 Honda Accord Coupe V6 1 Kenwood KDC-X692 Deck 2 Alpine Type S 6.5 in Doors 2 Alpine Type R 6x9" in Rear Deck 2 AQ HDC3 10's Dual 1's 2 C&D Technologies 75 Ah Batteries 4/0 Front to Rear 0 Gauge All Around Big 3 Included 1 American Bass 500.1 1 PPI ProArt A404 Old School 4-Channel Amp SOON: 300 Amp Excessive Amperage Alternator
IBleedMusick Posted November 10, 2011 Report Posted November 10, 2011 So i have a 97 Honda with im not sure the amperage off the alternator its either 85 or 95 but my question is would i be able to run 2 amps off it? i have a 10" L7 with an alpine mrp-500 right now. should i upgrade amps for the sub? and would i be able to put in another amp for the door speakers, also Kicker KS series 6.5's so not terribly large only maybe 50 rms per. i dont have a ton of money for the amps maybe 250 max right now but Christmas is coming up and the family is asking for ideas To answer your questions the stock alt should be fine for everything under 1000w, the alpine mrp-500 is fine if you can wire the sub down to 2 ohms and have it pushing 500w rms instead if not then to answer the question of would 200w make a difference...yes it would. Won't be huge but you will definitely know the difference. It's all on box design though you can make that 1 10" sound crazy in the right box. If you are planning to do the Big 3 don't half ass it just 0 gauge it from now that way if you decide to go larger later you're not redoing work. Darvex.com has everything you need to do a big 3 for a very affordable price and please don't go cheap on your wiring. GL with your build. 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
TeamHT Posted November 10, 2011 Report Posted November 10, 2011 :facepalm: Tell me...does this smell like chloroform to you?
