Adding Aux-Input to Aftermarket HU
Ok, so this might sound obscene or completely stupid but I would like to know if it can be done. First off, I plan on, eventually, doing a Carputer. So I have a Clarion CZ500 HU that does have a Aux Input on the face of it but not one on on the rear of the deck. I was wondering if there was some way to solder on a second Aux input (to the mobo of the HU), by branching off the main Aux-input, to the Clarion. Now I know this sounds stupid and feel free to criticize but I would like to know if this can be done. I am very familiar with electronics so no worries on soldering, testing, prodding, ect. The main reason I would like to do this is to be able to maintain the front aux free for an Ipod/Mp3/ect and have a Aux input in the back so I can maintain a neat look and not having to unplug and replug the carputer back in the front Aux port. I just would like to know if anyone has done it and/or if anyone knows off the top that it's not to hard to do. I figure I could do continuity test to find where to put the input but that's just a guess. If you need any more info, feel free to ask.
Feel free to hate to. I'm open for it.
if you wanted to you could probably add in an eq and retain the deck you have now, i know the legacy i have has two inputs on it, i dont know if the higher end models do or not
Edited by bass_stalker
Try it out on a older head unit first but i believe it sounds possible. you would just have to only use one or the other aux input. I am curious myself i do have an older hu i dont use that does have an aux. i may just try this out see how it goes.
Hmm I have a hifonics eq, but two potentiometers are broke of so I need to fix them, but I don't think It has an input....but I dont think that your plan would work to well because the EQ gets it's signal from the HU? Correct me if I'm wrong though? lol
Yea, I was going to see on my stock Calvalier head unit before I mess up this 90 buck one. It seems that this guy got it to work nicely on his RX-8 stock Head Unit so I assume it won't be terribly difficult on this Clarion. Here's the guys link, RX-8 Aux Input Install
get double din.almost all have inputs in rear. then get 3.5 audio jack to rca cable
You missed the point haha, I'm going to install a carputer...Which will be like a double din but 10000 better (imo) but I still want to retain the Clarion radio for many reasons. I rather not have a 7" touch screen AND a double din HU lol I'm also on a budget so I can't go out buying Head Units lol
not all eq's do. mine had what was labeled as DVD and aux and it was a little switch that would switch between the two rca inputs. i guess i should have asked if you had a highs amp first
ahhhhhh. i was thinking get the double n mount the car puter screen elsewhere so you can run shit from double din as cd n then puter as puter. my bad. i second the try it out thing cuz i have same problem
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
I believe I do, but it's an oldddd Virtual Reality amp so I might upgrade that to something of better quality and higher power. But I will look into the EQ and see if I can find one that I like that has it!
Thanks for the tip!
  • Who's Online   1 Member, 0 Anonymous, 950 Guests (See full list)
