Goyo Posted November 7, 2011 Report Posted November 7, 2011 Ok so say i make a 4ft^3 box and put a sub in it with .25 ft^3 displacement...so then my box is 3.75 ft^3 and say my port needs 14 sq inches per ft^3 do i go off of the volume before subwoofer is put in or after? im confused!
SnowDrifter Posted November 7, 2011 Report Posted November 7, 2011 Ok so say i make a 4ft^3 box and put a sub in it with .25 ft^3 displacement...so then my box is 3.75 ft^3 and say my port needs 14 sq inches per ft^3 do i go off of the volume before subwoofer is put in or after? im confused! Volume after the sub is put in ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
pa-pa-platypus Posted November 7, 2011 Report Posted November 7, 2011 your ports also gonna take up some room in the box unless you use external ports..and any kinda bracing you use in the box.. This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
Goyo Posted November 8, 2011 Author Report Posted November 8, 2011 your ports also gonna take up some room in the box unless you use external ports..and any kinda bracing you use in the box.. So say my port takes up .15 cu ft and my box comes out to be 3.6ft^3 and my subs recommended ported box volume is 4 cu ft now is the 4 cu ft after displacement of the sub and port?
Socky Posted November 8, 2011 Report Posted November 8, 2011 The 4cf is after all the displacement Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
