When do I know when I should get a second battery?
So you are suggesting doing the wiring upgrade called the "big 3" in the video posted by Adam, and getting a new battery under the hood?
right the big three is usually one of the first upgrades you would d. when you do the big three, make sure you use a good 0gauge wire and crimp/ solder your terminals good
Edited by bass_stalker
anything over a thousand watts would get an upgraded battery like a d3400, when you go to 2000 watts i would add another battery just to have a bit more reserve, assuming you have an alternator to support those batteries
dude a xs 3400 is wayy to much battery so to speak..i mean its never bad to have more reserve..but in his case its total overkill.. even on xs power website they suggest a much smaller battery..
do the big 3 upgrade in 0 gauge wire..and get a small battery in the back..the underhood battery is fine..(as long as it holds charge etc)... and make sure u have proper grounds
when i said that i meant the xs 3400 as a primary battery if he could fit it, which would be good up to 2500 watts.
ah ok i didnt see it was going in a honda chunk what i said lol
my co worker has a 98 civic coupe he runs a stock alt with the big 3 a shuirken bt20 under the hood and a shuirken bt35 in the back..he runs a hifonics 1000d on 2 type r 12s and a small 400 watt 4 channel..and he stays in the mid 13 volt range drivin down the road..\
just a idea of what some1 else has pushing basically same power
  • Who's Online   1 Member, 0 Anonymous, 1577 Guests (See full list)
