So you are suggesting doing the wiring upgrade called the "big 3" in the video posted by Adam, and getting a new battery under the hood?
right the big three is usually one of the first upgrades you would d. when you do the big three, make sure you use a good 0gauge wire and crimp/ solder your terminals good
Edited by bass_stalker
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
anything over a thousand watts would get an upgraded battery like a d3400, when you go to 2000 watts i would add another battery just to have a bit more reserve, assuming you have an alternator to support those batteries
dude a xs 3400 is wayy to much battery so to speak..i mean its never bad to have more reserve..but in his case its total overkill.. even on xs power website they suggest a much smaller battery..
do the big 3 upgrade in 0 gauge wire..and get a small battery in the back..the underhood battery is fine..(as long as it holds charge etc)... and make sure u have proper grounds
when i said that i meant the xs 3400 as a primary battery if he could fit it, which would be good up to 2500 watts.
o ok yea a bigger battery like that would be great as a primary and only battery..BUT sad thing is honda takes small ass batteries under the hood
ah ok i didnt see it was going in a honda chunk what i said lol
my co worker has a 98 civic coupe he runs a stock alt with the big 3 a shuirken bt20 under the hood and a shuirken bt35 in the back..he runs a hifonics 1000d on 2 type r 12s and a small 400 watt 4 channel..and he stays in the mid 13 volt range drivin down the road..\
just a idea of what some1 else has pushing basically same power
  • Who's Online   0 Members, 0 Anonymous, 2113 Guests (See full list)
