Ok so I go to install my hu do a quick test every thing works fine I go hook up the RCAs and USB and try to do a test and now the screen is all blurry/fuzzy. What could cause this? Is something I can fix?
you win some, you lose some
its feedback from something. move your wires around. if not could be a bad unit.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Maybe the RCA's have a bad ground? I have the 3200dvd and never had a problem with it.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
But the screen looks fine without the rca's plugged in? Try different rca's and make sure they arn't running by any power wires.
B5 Passat Build Log
Probably a bad unit then :shrug: If you get a new one don't be scared to get another pioneer double din, love mine.
This is the only idea I have to fix it although I doubt it will work...
Just download the video, loop it, then burn it to a dvd and let it play on the hu.
edit: Its usually used for only a few stuck pixels but I guess its worth a shot.
Edited by DjCrush
B5 Passat Build Log
bad unit then
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
