speaker wiring help =(
egag
ok so i have six 5 1/4 speakers and two 6x9's and i want to hook them all up to one amp
is this possible?
all of the speakers are 4ohm
and they are all around the same wattage RMS
would i just hook them all into the amp? or what would i have to do?
1994 Jeep Cherokee
!@#$%^&*(Soon to come)*&^%$#@!
TONS AND TONS of Audio Technix 80Mil
1 x 270 Amp Mechman Alt
1 x AQ3500D.1
1 x Rockford Fosgate T600-4
8 x Rockford Fosgate T2652-S
2 x XS Power D3100
1 x XS Power D3400
1 x eKs Kable 2 Channel Silver Plated RCA 5M
1 x Knukonceptz Kolossus Fleks Kable 1/0 Red 50FT.
1 x Knukonceptz Kolossus Fleks Kable 1/0 Black 50FT.
4 x Avenue - A605
2 x Fi Q 18
You could get a four channel that runs the amount of power you need per channel at 2 ohms seeing how that is what resistance the amp will see. Put two sets of 5.25's on the front channels and one set of 5.25's and the x 9's on the rear channel.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
is this possible?
That would not be a good idea, 4 4ohm speakers on 1 channel would be a 1 ohm load which is fine with a good amp. the reason i suggest against this idea is because it will be extremely hard to balance the output of so many speakers connected to a single amp. there are some options out there for multi-channel amps, like the Zed Audio Leviathan, which has 6 channels. this could allow you some more flexibility in your installation and tuning, along with having great power output, but you will still be forced to place 2 sets of speakers into a single channel.
best option, get 2 4-channel amps.
one 5 1/4 in each front/rear door two 5 1/4 in the rear hatch and two 6x9's in there own boxes behind the driver and passenger seat
1994 Jeep Cherokee
1 x AQ3500D.1
2 x XS Power D3100
1 x XS Power D3400
4 x Avenue - A605
2 x Fi Q 18
Which is why I sad a 4 channel. Most can handle a two ohm load easily.
i guess the question that really needs to be asked...
where are your speakers located or going to be located?
no...there doesnt need to be any further questions asked. roscoe is a vet and im pretty sure he knows his way around an amp.
Personally i would get 2 smaller 4 channel's
Run the first 4 5 1/4's off the first one. put the other two on the front channel of the second amp and the 6X9's on the back channel of the second amp.
That way you don't have any funky ohm loads everything that needs to match will (same speakers same channel) and you could adjust the 6X9's gain independent of the other 4 speakers since i bet they have a different power handling and would sound better on different settings than the 5 1/4's
.02
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
  • Who's Online   0 Members, 0 Anonymous, 1483 Guests (See full list)
