im having an issue connecting 3 1/0 ring terminals to my batt. i have 3 for negative and 3 for positive. so im looking for another way to hook them up that looks good any ideas would be awesome thanks!!!!!
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
Aluminum or copper flats stock I use 2 1/2 in by 3/8 by 5in then dill holes for battery post bolt then multiple hole usually 6 with 5/16 by 1 1/2 bolts washers and nuts
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
where can i get something like that?
BIG 3
RF T400.4
all stinger wires
You can reorganize your runs. Run a run off the alternator. Run a negative run off the run at the frame (that completes the big 3). Bus bars are nice but 6 runs isn't that big of a deal... There's definitely more than one way to go about it.
toolmaker, check him on caco
why if you dont want it to be pretty you make it yourself go to ace hardware or menards and have a drill press and make your own holes it works just fine and saves you alot of money
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
no drill press or i would have made my own distribution blocks and been done with it
BIG 3
RF T400.4
all stinger wires
or that
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
  • Who's Online   0 Members, 0 Anonymous, 2595 Guests (See full list)
